Como um carro feito em 1997 pode ser 1998/1998????????
Segue o ficha do meu carro, como ele pode ser 1998/1998 se o "delivery date 09.12.97" ?????? Isso é serio???? Eles vendem carro fabricado em 1997 como se ele tivesse sido fabricado em 1998????
ABS e Obrigado
Alexandre
VIN WDBHA89W7WF689609
Plant 67
Model C 280
Chassis 2020891F689609
Engine 112920 30 111133
Transmission 722606 00 682740
Tyres
Primary MICHELIN
Order 0 8 775 80453
Lights VALEO
Delivery date 09.12.97
Dealer Brazil (775)
Interior leather black or graphite (201)
Paint
197 obsidian black metallic (с 1978)
Options
058 aej. 97/2 (с 09.12.1995)
221 left front seat, electrically adjustable (с 01.11.1978)
222 right front seat, electrically adjustable (с 01.11.1978)
240 outside temperature indicator (с 01.03.1982)
249 automatically dipping inside rear view mirror (с 01.06.1990)
292 sidebag in front left and right (с 01.01.1994)
345 rains sensor for windshield wipers (с 01.10.1993)
414 electric tilting/sliding roof in glass version (с 01.10.1988)
423 5 speed automatic transmission / nag (с 01.03.1994)
441 steering column, electrically adjustable, W202 manually adjustable (с 01.07.1984)
481 undershields (с 01.10.1962)
524 paintcoat preservation (с 01.01.1964)
543 sun visor with vanity mirror, illuminated, left and right (с 01.11.1978)
551 anti-theft warning system (с 01.11.1978 по 31.03.1998)
570 folding armrest front w202/210 stowage box front with armrest (с 01.04.1970)
front folding armrest w202 - housing at front with armrest
581 automatic climate control (с 01.01.1977)
584 electric window lifters (front and rear doors) (с 01.04.1970)
electric window lifters, fourfold or sixfold
611 courtesy lamps for front and rear doors, with W124 also for central doors/W202 front doors only (с 01.11.1978)
656 light alloy wheels, 10-hole (с 01.06.1993)
668
673 high-capacity battery (с 01.01.1964)
682 fire extinguisher (с 01.04.1970)
755 radio MB Special cd (с 22.05.1996)
808 Change of year of model, last figure shows new model year
837 rubber mats on front floor and rear floor; with chassis, front only; with station wagon, including loading floor (с 01.11.1969)
955 extension tube on the roof, front
equipment package elegance (с 01.11.1991)
986 identification plate (vin no.) (с 01.07.1992)
987 battery cut-off switch for vehicles to be shipped (с 01.02.1993)
ABS e Obrigado
Alexandre
Plant 67
Model C 280
Tyres
Primary MICHELIN
Order 0 8 775 80453
Lights VALEO
Dealer Brazil (775)
Paint
Options
668
Alexandre Alcure- Usuário Iniciante
- Número de mensagens : 38
Data de inscrição : 06/08/2008
Re: Como um carro feito em 1997 pode ser 1998/1998????????
Acho que poder não pode.
Da uma olhada na plaquinha e confirma. Classe C acho que só é feita em Bremen.
Krycek- Usuário Platina
- Número de mensagens : 8300
Ela é uma 280T (touring)
E veio com o seguinte opcional 808: CHANGE OF YEAR OF MODEL, LAST FIGURE SHOWS NEW MODEL YEAR.
abs,
abs,
Geeente... q coringa! Quero uma que aperte o botão vire 2008!
Mas a placa do motor diz o q?
Ihhh to sentindo brecha na lei:
"Europe: In the automotive industry the "model year" is absolutely defined only by the manufactuer, and NOT any local vehicle registration practices, or media marketing opinions.(...) The 10th VIN digit does NOT relate to the calendar year which the car is built, although the two may coincide."
Creio que o correto nesse caso, é o Alexandre entrar em contato com o SAC da Mercedes e tentar obter a informação correta.
Eu estou esperando passar o carro para o meu nome para levar ele na intercar e tentar descobrir que opcional é esse que muda o ano e fabricação do carro, é no minimo muito interessante.
Quero saber se esse opcional tambem e oferecido nos EUA e na EUROPA ou é só para o Brasil.
Até pq na minha opiniao como o carro realmente foi feito em 1997 é melhor ter um carro 97/98 do que ter um carro que foi feito em 97 e no documento aperece 98 uma vez que o IPVA é calculado com base no ano da fabricação e nao no modelo.
Alexandre
Alexandre
Acho que o último lugar que vão saber isso é na Intercar... uma vez quebrei o pau com o gerente e o vendedor pq eles sismaram que a R171 tinha chegado a partir de 06 e todo mundo sabe q é 05. Acho q vão inventar uma abobrinha qualquer bem difícil de engolir e vão querer cobrar um taxa extra pela raridade da ocorrência
Alexandre,
Sinceramente creio que isso não seja só para o Brasil. Toda a industria automobilistica, faz uma serie de alterações no carro visando a padronização conforme o ano e o modelo. Creio que o significado desse "opcional" é que o carro apesar de ter sido fabricado em 97 tem todas as características do 98/98. Não creio que a MB na Alemanha, esteja muito preocupada com o ano modelo por causa do IPVA e coisas parecidas. Também não sei se essa pratica é comum entre os carros importados. Creio que somente o SAC da Mercedes Benz pode te esclarecer esse fato. Esse carro tem o DATACARD original?
eu tenho o data card original, vou colocar aqui, mas na pratica qual é a diferenca entre um 97/98 e um 98/98?
Alexandre,
Detalhes. A minha AMG é 99/99, examinado uma 98/99 achei uma pequena diferença no console. Na verdade é uma necessidade de padronização do produto que a fabrica precisa ter. Nos carros antigos acho que a coisa era mais confusa. Eu tenho um livro da 300SL, que mostra as variações na linha de montagem conforme o numero de serie. Por exemplo a partir do numero tal. a manivela do vidro era alterada. As vezes são coisas importantes, como a troca de tambor para disco. Nos carros modernos, creio que são detalhes mínimos, para facilitar a manutenção. De qualquer forma, só o SAC da MB pode informar com certeza. lembrando tb que o site russo não é oficial MB.
A Fiat ( arghh) é campeã dessas alterações dentro do mesmo ano modelo . Quando preciso fazer alguma espécie de manutenção nas Fiorinos da empresa , faz-se necessário desmontar e levar a peça , pois o simples fato de informar ano , modelo e motorização não é suficiente para determinar qual a peça exata de reposição . Isso vale para faróis , cilindros de freio , correia dentada , amortecedores etc..
Fabio- Usuário Platina
- Número de mensagens : 1391
» Teste da GL63AMG feito no Brasil feito por Motorgrid
» C180 - 1997 / 1998 - Compatibilidade de Peças
» C140 CL600 1997/1998 - R$ 149.000,00
» Vendo C 280 1997/1998 V6 - R$ 28.000,00 VENDIDO
» C180 1997/1998 22 cv a mais?
